KC868-A16 ESPHome yaml for DHT11/ds18b20 RF - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: KC868-A16 ESPHome yaml for DHT11/ds18b20 RF (/showthread.php?tid=2431) |
KC868-A16 ESPHome yaml for DHT11/ds18b20 RF - stanchiam - 12-09-2022 Hi, I am using ESPhome and home assistant, tried the below yaml using REV1.5 board but not sure how to get the temperature sensor and RF receiver/transmitter(already installed) working on HA. Is my yaml correct? I am not sure about the pin number used, from the board i see the dht data cable is fixed at HT3. Please help take a look at the yaml and also how to use with HA. Unable to find info for ESPHome and HA using KC868-A16. remote_receiver: pin: 2 dump: rc_switch # Settings to optimize recognition of RF devices tolerance: 50% filter: 250us idle: 4ms buffer_size: 2kb remote_transmitter: pin: 15 carrier_duty_percent: 100% # Example configuration entry for sensor sensor: - platform: dht pin: 14 temperature: name: "Temperature" humidity: name: "Humidity" update_interval: 10s # - platform: dallas # pin: 14 # address: 0x1c0000031edd2a28 # name: "ds18b20-1" RE: KC868-A16 ESPHome yaml for DHT11/ds18b20 RF - admin - 12-09-2022 here is pins define for KC868-A16: DS18B20/DHT11/DHT21/WS2812 LED strip -1: 32 DS18B20/DHT11/DHT21/WS2812 LED strip -2: 33 DS18B20/DHT11/DHT21/WS2812 LED strip -2: 14 RF433MHz wireless receiver: 2 RF433MHz wireless sender: 15 I suggest you test step by step. such as test DHT11 firstly, delete your RF config firstly. when DHT is work well, then add RF module to ESPHome. RE: KC868-A16 ESPHome yaml for DHT11/ds18b20 RF - admin - 12-09-2022 can you take a photo, how you wire your sensor and RF module with your KC868-A16 board. RE: KC868-A16 ESPHome yaml for DHT11/ds18b20 RF - stanchiam - 12-09-2022 (12-09-2022, 01:43 AM)admin Wrote: can you take a photo, how you wire your sensor and RF module with your KC868-A16 board. (12-09-2022, 01:33 AM)admin Wrote: here is pins define for KC868-A16: tried, remove rf, only left sensor but still not showing in HA or inside the esphome web server sensor: - platform: dht pin: 14 temperature: name: "Temperature" humidity: name: "Humidity" update_interval: 10s RE: KC868-A16 ESPHome yaml for DHT11/ds18b20 RF - stanchiam - 12-09-2022 Resolved, i update the esphome via the lan network and though it was ok, but it is not. I power off and on then use the usb option to install. Then it appear. RE: KC868-A16 ESPHome yaml for DHT11/ds18b20 RF - admin - 12-09-2022 ok , great. update to newest version always a good way to solve problem. |
