Serial command ?? - Printable Version
+--- Forum: KC868-A4 (https://www.kincony.com/forum/forumdisplay.php?fid=21)
+--- Thread: Serial command ?? (/showthread.php?tid=2515)
Serial command ?? - vincen - 01-15-2023
Hi
First time trying to use serial control with HA (have done it for years with antic automation system like AMX, Crestron ones) but I struggle to get it working with HA and ESPHome.
I'm using the Kincony K868-A4 box https://www.kincony.com/arduino-esp32-4-channel-relay-module.html to get a serial port.
I have tried wiring serial port between kincony and device controlled straight or crossed but not better ! (product was controlled previously without problems by a Crestron system).
Here is code used in ESPHome:
substitutions:
  friendly_name: esp-tr-02
  platform: ESP32
  board: esp32dev
web_server:
ota:
wifi:
  networks:
  - ssid: !secret wifi_ssid
    password: !secret wifi_passwd
  manual_ip:
    static_ip: 172.16.2.81
    gateway: 172.16.1.1
    subnet: 255.255.252.0
  ap:
    ssid: $friendly_name
captive_portal:
  reboot_timeout: 10min
#  services:
#    - service: volume
#      variables:
#        volume: Int
#      then:
#        - uart.write: !lambda
#            return {0x00, 0x20, 0x42};
  - platform: uptime
    filters:
      - lambda: return x / 60.0 /60.0;
    unit_of_measurement: hours
  - platform: wifi_signal
    name: $friendly_name WiFi Signal
    update_interval: 60s
button:
  - platform: template
    on_press:
      - uart.write: "CD\r"
    on_press:
      - uart.write: "DV\r"
uart:
  tx_pin: GPIO17
  rx_pin: GPIO16
  baud_rate: 9600
  debug:
Protocol of the device I try to control: https://cloud.domedia.net/index.php/s/g6ANGP9CLbaG7iK
Any ideas what's wrong here ?
Thanks
Vincèn
RE: Serial command ?? - admin - 01-16-2023
i think firstly, you can send RS232 command by PC to test your command whether is correct.
if your command is correct, then try to config by ESPHome to send command.
RE: Serial command ?? - vincen - 01-16-2023
(01-16-2023, 01:15 PM)admin Wrote: i think firstly, you can send RS232 command by PC to test your command whether is correct.
I know the syntax of commands and I'm sure they work ! My only problem is to get them working with the Kincony through it's RS-232 port !
Can you confirm my ESPHome code is correct ?
RE: Serial command ?? - admin - 01-17-2023
1. suggest you use KC868-A4's digital input make for 4 buttons for test.
number: 36
number: 39
number: 27
number: 14
2. you can add these for a test:
on_...:
- uart.write: 'CD'
3. if can't work, you can try to exchange your RXD,TXD pin, such as :
uart:
tx_pin: GPIO16
rx_pin: GPIO17
baud_rate: 9600
