KinCony "KCS" 2023 new firmware under developing - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: News (https://www.kincony.com/forum/forumdisplay.php?fid=5) +--- Thread: KinCony "KCS" 2023 new firmware under developing (/showthread.php?tid=2516) Pages:
1
2
KinCony "KCS" 2023 new firmware under developing - admin - 01-15-2023 "KCS" means “KinCony Super” , this is a new firmware developed by KinCony for KC868-A series products in 2023. It has powerful functions and supports multiple communication protocols. It can manage various functions of the device through web pages, such as: input configuration, output configuration, monitoring management page, Timing schedule task mode, network configuration, communication protocol configuration, system configuration and other related functions Input configuration: Binding of digital input port and output port, setting of effective value of high and low level, support multiple trigger modes through digital input port, such as: single click, double click, hold on mode Output configuration: Output level invert, support delay auto off, support jog mode control, support interlock setting monitoring management page: Monitor the status of the input in real time through the web page, and manually control the output Timing schedule task mode: Support custom scheduled tasks by year, month, day, hour, minute Network Configuration: configuration of ethernet and wifi Communication protocol configuration: Support MQTT, HTTP, TCP Server, TCP Client, UDP Server, UDP Client, Modbus multiple communication protocols Tuya App configuration: Configure Tuya app license to remote control board by internet System Configuration: default parameter settings RE: KinCony "KCS" 2023 new firmware under developing - benlouisv@gmail.com - 03-19-2023 When I change the DAC Settings in my tuya app it tells me Failed to save. What can I do? RE: KinCony "KCS" 2023 new firmware under developing - admin - 03-19-2023 you can save again, whether work well. RE: KinCony "KCS" 2023 new firmware under developing - benlouisv@gmail.com - 03-19-2023 (03-19-2023, 09:05 AM)admin Wrote: you can save again, whether work well. I tried again but this is what I get when I change the DAC value on the slider (03-19-2023, 09:05 AM)admin Wrote: you can save again, whether work well. I tried again but this is what I get when I change the DAC value on the slider RE: KinCony "KCS" 2023 new firmware under developing - admin - 03-19-2023 which board model you are using? RE: KinCony "KCS" 2023 new firmware under developing - benlouisv@gmail.com - 03-19-2023 K868 A6 RE: KinCony "KCS" 2023 new firmware under developing - benlouisv@gmail.com - 03-20-2023 Any assistance why I cannot adjust the DAC in tuya app? RE: KinCony "KCS" 2023 new firmware under developing - admin - 03-21-2023 your question have replied in your another topic. RE: KinCony "KCS" 2023 new firmware under developing - krzycholek - 04-01-2023 Hello, Is the KCS firmware open-source? If not, I'd like to request for a feature: additional input function "state change" in input tab. That feature would be useful for traditional (bi-stable) switch. RE: KinCony "KCS" 2023 new firmware under developing - admin - 04-01-2023 do you means, want support INPUT trigger OUTPUT by traditional switch panel? |
