Colb - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: Colb (/showthread.php?tid=2541) |
Colb - Yazaww - 01-28-2023 Hello, I have a small question about colb temperature input, what kind of sensor i must use since it has 3 terminals? So i cant use temperature sensor with 2 wires? Or how? RE: Colb - admin - 01-29-2023 that use DS18B20 temperature sensor, use Vcc, Data and GND. RE: Colb - admin - 01-29-2023 https://www.kincony.com/how-to-use-ds18b20-temperature-sensor.html here is diagram of sensor's PIN define. RE: Colb - Yazaww - 01-29-2023 So i cant use any other temperature sensor ? Like pt100? Or anything else RE: Colb - admin - 01-29-2023 you can use any dc 0-5v output signal sensor. if you want to use pt100, you need add a circuit convert pt100 resistance -> 0-5v signal. there are some convert module in market. |
