Full automation of boiler room - what component to use - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: DIY Project (https://www.kincony.com/forum/forumdisplay.php?fid=3) +--- Thread: Full automation of boiler room - what component to use (/showthread.php?tid=2608) |
Full automation of boiler room - what component to use - mmetal - 02-25-2023 Hello, this year i was finished installation of my new boiler room with 3 boilers, 16 pumps, 16 electric valves, one pellet burner... Now i need to make automation of all components. I was test some process with sonoff TH16 and 4CH pro devices and home assistant, only to see what exactly need and can to controll, and the main problem is that i need a lot of temperature sensors, pressure sensors, ultrasonic sensors, relays, contactors etc. The best solution is to use home assistant, but if you have some suggestions, i am open In text bellow i will try to explain what i plan to do, and it would be great that you suggest me components for my automation
I hope that you will understand what i need. Please suggest me what componnent i should use. If you need additional information, please contact me Thanks in advance RE: Full automation of boiler room - what component to use - admin - 02-26-2023 if you have many sensors want to add to home assistant, suggest use KC868-COLB input module or KC868-AI. KC868-COLB have 16 channel "digital input" and 16 channel "analog input" (dc 0-5v ) and 5 channel DS18B20 temperature sensor. KC868-AI have 48 channel "digital input" . so you just need to chose the sensor is dc 0-5v output signal type. about relay board, there are many model can chosed. just suggest by ethernet way is stable. |
