A32 Input voltage range - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A32/A32 Pro (https://www.kincony.com/forum/forumdisplay.php?fid=27) +--- Thread: A32 Input voltage range (/showthread.php?tid=2624) |
A32 Input voltage range - Shaps77 - 03-02-2023 What is the acceptable tolerance of the input voltage for the KC868-A32? RE: A32 Input voltage range - admin - 03-02-2023 do you means power supply or digital input port? RE: A32 Input voltage range - Shaps77 - 03-02-2023 (03-02-2023, 05:58 AM)admin Wrote: do you means power supply or digital input port? The board 12v input. What is the acceptable +/- range? Thank you RE: A32 Input voltage range - admin - 03-02-2023 because relay coin is DC12v. so not >12v RE: A32 Input voltage range - Shaps77 - 03-02-2023 (03-02-2023, 06:36 AM)admin Wrote: because relay coin is DC12v. so not >12v Thank you
RE: A32 Input voltage range - admin - 03-02-2023 you are welcome |
