KC868-H16 TCP PHP sample code - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: KC868-H16 TCP PHP sample code (/showthread.php?tid=2673) |
KC868-H16 TCP PHP sample code - jfementira - 03-13-2023 I'm using KC868-H16. How to run tcp send and receive command using php? RE: KC868-H16 TCP PHP sample code - admin - 03-13-2023 see this guide about PHP tcp socket connection code: https://www.php.net/manual/en/function.socket-connect.php RE: KC868-H16 TCP PHP sample code - jfementira - 03-13-2023 (03-13-2023, 04:35 AM)admin Wrote: see this guide about PHP tcp socket connection code: So it is just a string to send to the server/device? Sample: PHP Code: $message = 'RELAY-SET-255,1,0'; RE: KC868-H16 TCP PHP sample code - admin - 03-13-2023 yes, very easy. $message = 'RELAY-SET-255,1,1'; //turn on relay1 $message = 'RELAY-SET-255,1,0'; //turn off relay1 RE: KC868-H16 TCP PHP sample code - jfementira - 03-13-2023 (03-13-2023, 06:19 AM)admin Wrote: yes, very easy. Awesome, Thank you. I have a Smart City and BMS project this year. I will use this product from one of my integration. RE: KC868-H16 TCP PHP sample code - admin - 03-13-2023 ok, thanks, test with first controller. good luck. |
