KS868-A Series multiple questions - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-A series and Uair Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=6) +--- Thread: KS868-A Series multiple questions (/showthread.php?tid=2683) |
KS868-A Series multiple questions - spacerunner - 03-14-2023 Hi, just a fest questions about different A-Series ESP32 controllers: 1. Are the dry contact inputs of the KCS868-AI the same as on the KC868-A16/64/128 ? (anti-interference, ling range etc) 2. Can the dry contact inputs of KCS868-AI or KC868-A16/64/128 also be driven by external voltage, such as +5V or +12V? 3. Can the MOSFET outputs of KC868-A16/64/128 also drive +5V instead of 12V/24V? 4. Can the MOSFET outputs of KC868-A16/64/128 drive different voltages per 8-PIN-Block? For example 12V output on A1-A8, 24V output on B9-B16, 5V output on B73-B80? RE: KS868-A Series multiple questions - admin - 03-14-2023 1. yes, all KC868-A series board digital input is same. 2. dry contact input can work for +12v , that means logical "1", acutally >5v for logical "1" is stable. 3. sure, just every 8 channel have "Vin" , you can connect with different voltage, so that mosfet will output different voltage. 4. sure, you are right. every 8 channel mosfet use by one power supply independently. RE: KS868-A Series multiple questions - spacerunner - 03-14-2023 Thank you, so just to make sure again: 1. Driving +5V MOSFET output ist OK? 2. What is the MOSFET output voltage RANGE? RE: KS868-A Series multiple questions - admin - 03-14-2023 1. yes, it's ok. 2. RANGE= 5v---24v DC |
