Need firmware with MQTT for Smart dimmer - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: Need firmware with MQTT for Smart dimmer (/showthread.php?tid=274) |
Need firmware with MQTT for Smart dimmer - Gooogle - 05-14-2021 There will be firmware for Smart dimmer with MQTT RE: Need firmware with MQTT for Smart dimmer - admin - 05-14-2021 There are no plans at the moment. RE: Need firmware with MQTT for Smart dimmer - Gooogle - 05-22-2021 We need Smart dimmer MQTT protocol. Because now we don't see the status or ledstripe on or off. When I turn off the ledstrip with the wall switch, the status of the home assistant in the dashboard does not change. RE: Need firmware with MQTT for Smart dimmer - admin - 05-23-2021 Do you use Node-Red integrate with home assistant? RE: Need firmware with MQTT for Smart dimmer - Gooogle - 05-23-2021 Yes I use node-red RE: Need firmware with MQTT for Smart dimmer - admin - 05-24-2021 now you can place a timer to update dimmer state every some seconds (send read dimmer state command by TCP socket connection). maybe in furture, we will update KC868-D8 for MQTT. RE: Need firmware with MQTT for Smart dimmer - Gooogle - 05-24-2021 Maybe you can send a sample node red flow configuration? How to do it, I tried but I don't work for me. RE: Need firmware with MQTT for Smart dimmer - admin - 05-25-2021 https://www.kincony.com/forum/showthread.php?tid=87 here is Node-Red flows download link, there is sampe KC868-D8 dimmer controller for Apple Homekit integration. |
