I-O testing board - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: I-O testing board (/showthread.php?tid=2749) |
I-O testing board - Olsen@HuaHin - 03-29-2023 Hi I received my KC868-A16 board last week and are at the moment testing I-O before starting to write any Arduino code. My firmware is the latest version 1.0.19 I can from the web portal activate each output, but I cannot see any incoming inputs and they will not toggle assigned output. I am using the 12v dc from your supplied power supply and I connected GND to input terminals. Any idea what I am doing wrong. RE: I-O testing board - admin - 03-29-2023 your wire is wrong. every Digital input short with GND = trigger. how to trigger see "yellow" wire in image. RE: I-O testing board - Olsen@HuaHin - 03-29-2023 I had expected a trigger of 12vdc according to specifications. Anyway, thanks for the clarification ![]() RE: I-O testing board - admin - 03-29-2023 because your cable always connect with dc12v, that means NOT trigger. INPUT with GND is trigger. |
