KC868-A16 support mmWave Sensor? - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: KC868-A16 support mmWave Sensor? (/showthread.php?tid=2751) |
KC868-A16 support mmWave Sensor? - jhobson - 03-30-2023 Hi Admin, Could you please advise if it is possible to run mmWave sensor (like: https://www.aliexpress.com/item/1005005047841163.html ) using KC868-A16 ? RE: KC868-A16 support mmWave Sensor? - admin - 03-30-2023 if you want to use, the sensor is serial output, you can convert to RS485 port, then can use for KC868-A16. |
