KS868-A16 Questions - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-A series and Uair Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=6) +--- Thread: KS868-A16 Questions (/showthread.php?tid=2753) |
KS868-A16 Questions - Olsen@HuaHin - 03-31-2023 Hello everybody! I am new to the ESP32 board and just got myself the KS868-A16. My first choice was to use Arduino IDE to program my board. After writing my first Sketch I found out the Debugging for the ESP32 board is not directly supported Has anyone found a working solution for this as I would like to be able to see status, test and troubleshoot my code. Tried to Google the subject but has not been able to find an easy fix. I have been looking at other options like Tasmota & ESPHome and Home Assistant. Does any of those two platforms has a debugger? I preferer a standalone system instead using a dedicated system. My project is for the time being a small home control of 6pcs indoor light controls, time controlled outdoor night-light with 3pcs PIR and dimmer, armed-disarmed indoor alarm system with 4pcs PIR sensors. Any recommendation to which platform to use, Arduino, Tasmota or ESPHome as I would like to write of standard code. Any feedback is appreciateded RE: KS868-A16 Questions - admin - 03-31-2023 if you want standalone system, you can use "tasmota" or "ESPHome" or kincony "KCS" fimrware. also you can write your own arduino code. RE: KS868-A16 Questions - Olsen@HuaHin - 03-31-2023 Can I add own arduino code to the KCS firmware RE: KS868-A16 Questions - admin - 03-31-2023 no, "KCS" just directly to use. RE: KS868-A16 Questions - Olsen@HuaHin - 03-31-2023 Thanks for the clarification to standalone system. Does anybody have a reply to my question about a way to debugging in Arduino as I am not able to find an easy way from Google search? RE: KS868-A16 Questions - admin - 03-31-2023 we have many A6 arduino demo source code you can use. just first step you should install the arduino IDE and config setting. here is video tour: https://youtu.be/sQUVpHliHzo here is our arduino lessons video tour playlist: https://www.youtube.com/playlist?list=PLQUWhE_6LeOSOXC9NWL8g5qnkgAdy4gON RE: KS868-A16 Questions - Olsen@HuaHin - 03-31-2023 I have no problem with getting a Sketch up running. My question is if somebody has got the debugger working? I have done your suggested google search: There are two requirements for support to be available for use of the Arduino IDE integrated debugger with the ESP32 boards: 1. The debugger extension must have support for the ESP32 target 2. The ESP32 boards platform authors must configure their platform to provide the necessary information to the debugger. I am not able to find an easy way to get debugger running, has anybody found a work around? |
