New project - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: DIY Project (https://www.kincony.com/forum/forumdisplay.php?fid=3) +--- Thread: New project (/showthread.php?tid=2760) |
New project - revenson - 04-04-2023 I am building a house, tell me what is better to use for a smart home: 16 group curtains and roller shutters (I have an RR06 receiver under the roller shutter and I need to connect it to a low current switch and see them in the home assistant) ). I want to manage underfloor heating, I have 2 floors and warm floors everywhere, it is desirable to manage separately separately. I will also have RGB in my room and the lighting will also control it (about 5 rooms with RGB), and around the house there will also be ice in the caecum, but an ordinary tape, 300 meters of tape in a circle. There is also a snow melting system in a circle (ProfiTherm D-4, D-3, ProfiTherm Eko Plus), the shower would be controlled. Lighting will also be about 50 groups. Cameras in a circle (I want to implement the structure of faces) Also interested in IC management. I have a rassbury pi 4 8gb. RE: New project - admin - 04-04-2023 can you write in English? RE: New project - revenson - 04-04-2023 (04-04-2023, 07:18 AM)admin Wrote: can you write in English? I have corrected RE: New project - admin - 04-04-2023 i think you can chose KC868-A series board, it's easy integrate to home assistant by ESPHome. for lamps, for RGB leds, for IR control system. here is products list, you can check: https://www.kincony.com/download/KinCony-IoT-order-list-V25.xlsx RE: New project - revenson - 04-04-2023 (04-04-2023, 11:49 AM)admin Wrote: i think you can chose KC868-A series board, it's easy integrate to home assistant by ESPHome. for lamps, for RGB leds, for IR control system. How do you control underfloor heating? RE: New project - admin - 04-04-2023 use our smart relay controller + AC contactor. RE: New project - revenson - 04-14-2023 Tell me, I will have 6 RGBW + CCT channels, what do you recommend to manage? RE: New project - admin - 04-14-2023 what software will use? RE: New project - revenson - 04-14-2023 home assistant RE: New project - admin - 04-15-2023 (04-14-2023, 08:23 AM)revenson Wrote: Tell me, I will have 6 RGBW + CCT channels, what do you recommend to manage? suggest use KC868-AP for this. just set by ESPHome in home assistant. |
