KC868-A4 released! You can write any code by Arduino IDE - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: News (https://www.kincony.com/forum/forumdisplay.php?fid=5) +--- Thread: KC868-A4 released! You can write any code by Arduino IDE (/showthread.php?tid=279) |
KC868-A4 released! You can write any code by Arduino IDE - admin - 05-27-2021 KC868-A4 smart controller , many hareware resource for you to use, you can write any code by Arduino IDE to ESP32 wifi/bluetooth module. We will supply demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. ![]() Here is resource list: WiFi/Bluetooth*1 RS232*1 Relay Output*4 Digital Input*4 433M Transmit PCB port*1 433M Receiver PCB port*1 IR receiver*1 IR sender*1 Analog input (DC0-5V)*2 Analog input (4-20mA)*2 Analog output(DC0-10V)*2 temperature and humidity sensor port*1 Buzzer*1 RE: KC868-A4 released! You can write any code by Arduino IDE - auricaionut466@gmail.com - 09-17-2021 hello I bought this KC868-A4 board and I want you to help me with some examples of arduino codes Thank you RE: KC868-A4 released! You can write any code by Arduino IDE - admin - 09-18-2021 arduino IDE have many example code. every our video tour have code can be download. what need help ? RE: KC868-A4 released! You can write any code by Arduino IDE - auricaionut466@gmail.com - 09-19-2021 I want to know if I can simulate analog input A1 and A2 with this device: https://www.aliexpress.com/item/32868412260.html?aff_fcid=78c6d19ae2bc4715a828ca9bddd7c9aa-1632040935704-02305-_dUhZJUD&aff_form_aff&A _dUhZJUD & aff_trace_key = 78c6d19ae2bc4715a828ca9bddd7c9aa-1632040935704-02305-_dUhZJUD & terminal_id = 7ba797a8532642b4a9359a75d6ab4bcf RE: KC868-A4 released! You can write any code by Arduino IDE - admin - 09-19-2021 yes, support. you can let this Generator output 4-20mA connect to A4 board's analog input (4-20mA) port. |
