KC868-A8M ESP32 I/O pin define - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A8M (https://www.kincony.com/forum/forumdisplay.php?fid=48) +--- Thread: KC868-A8M ESP32 I/O pin define (/showthread.php?tid=2790) |
KC868-A8M ESP32 I/O pin define - admin - 04-14-2023 #define ANALOG_A1 34 #define ANALOG_A2 35 #define ANALOG_A3 36 #define ANALOG_A4 39 IIC SDA:5 IIC SCL:4 Relay_IIC_address 0x24 Input_IIC_address 0x22 DS18B20/DHT11/DHT21/LED strip -2: 14 RF433MHz wireless receiver: 16 Ethernet (LAN8720) I/O define: #define ETH_ADDR 0 #define ETH_POWER_PIN -1 #define ETH_MDC_PIN 23 #define ETH_MDIO_PIN 18 #define ETH_TYPE ETH_PHY_LAN8720 #define ETH_CLK_MODE ETH_CLOCK_GPIO17_OUT GSM/RS485: RXD:GPIO15 TXD:GPIO13 CAN bus: TXD:GPIO32 RXD:GPIO33 RE: KC868-A8M ESP32 I/O pin define - Smirnowegor - 12-24-2024 GSM/RS485: RXD:GPIO15 TXD:GPIO13 CAN bus: TXD:GPIO32 RXD:GPIO33 Hi, do you have any examples how to use Can or RS485? Maybe some examples with address delivery and sensor input. Thank you! RE: KC868-A8M ESP32 I/O pin define - admin - 12-24-2024 you can download KCS firmware to board. Then you can use RS485 modbus. here is KCS v2 online guide: https://www.kincony.com/esp32-kcsv2-firmware.html |
