KC868H16 and Home Assistant ? - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: KC868H16 and Home Assistant ? (/showthread.php?tid=285) |
KC868H16 and Home Assistant ? - Max - 06-09-2021 Hi, the KC868H16 is supported by Home Assistant ? If yes, there is a youtube tutorial ? Thanks. RE: KC868H16 and Home Assistant ? - admin - 06-09-2021 yes, H16 use by Node-Red+Home assistant. have video tour on YouTube. RE: KC868H16 and Home Assistant ? - Max - 06-10-2021 Ok. Is this youtube page : https://www.youtube.com/watch?v=Yrat7hVzXRw for install it ? The new firmware is on your site ? How I dowlnoad this firmware in my KC868H16B ? Thanks. RE: KC868H16 and Home Assistant ? - admin - 06-11-2021 the new firmware of MQTT function is for KC868-H32B, not for H16B. You don't update firmware. H16B how to work with home assistant, here are playlist: https://www.youtube.com/playlist?list=PLQUWhE_6LeOSgQcfv2UendJgZqNiwV92_ just install Node-Red and home assistant, because let H16B connect to Node-Red, Home assistant link with Node-Red to work. |
