KC868-AP ESPHome demo config switch panel control LED for home assistant by ethernet - Printable Version
+--- Forum: KC868-AP / ADR (https://www.kincony.com/forum/forumdisplay.php?fid=38)
+--- Thread: KC868-AP ESPHome demo config switch panel control LED for home assistant by ethernet (/showthread.php?tid=2889)
KC868-AP ESPHome demo config switch panel control LED for home assistant by ethernet - admin - 05-08-2023
this is config file for digital input1 with button control KC868-AP output1:
1: click button for ON/OFF LED,
2: hold on button for change led brightness.
[Image: attachment.php?aid=2392]
[Image: attachment.php?aid=2393] esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
  encryption:
    key: "hx8eSqbwjWs9/2bK0qK55QfTIOpI4gCfzLOeaOXZMaU="
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  sda: 4
  scl: 16
pcf8574:
  - id: 'pcf8574_hub_in_1'  # for input channel 1-8    maybe 0x22  /  0x3A
    address: 0x22
    address: 0x21
      pcf8574: pcf8574_hub_in_1
      mode: INPUT
    on_click:
      then:
        - if:
            condition:
              light.is_off: light_1
            then:
              light.turn_on:
                brightness: 1.0
            else:
              light.turn_off: light_1
    on_press:
      then:
      - if:
          condition:
          then:
          - delay: 0.5s
          - while:
              condition:
                binary_sensor.is_on: light_1_touch
              then:
                - light.dim_relative:
                    relative_brightness: 5%
                    transition_length: 0.1s
                - delay: 0.1s
          else:
          - delay: 0.5s
          - while:
              condition:
                and:
                  - binary_sensor.is_on: light_1_touch
                  - light.is_on: light_1
              then:
                    relative_brightness: -5%
                - delay: 0.1s
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      pcf8574: pcf8574_hub_in_2
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      number: 34
      number: 35
pca9685:
    frequency: 500
output:
  - platform: pca9685
    pca9685_id: 'pca9685_hub'
    channel: 0
  - platform: pca9685
    channel: 1
  - platform: pca9685
    channel: 2
  - platform: pca9685
    channel: 3
  - platform: pca9685
    channel: 4
  - platform: pca9685
    channel: 5
  - platform: pca9685
    channel: 6
  - platform: pca9685
    channel: 7
  - platform: pca9685
    channel: 8
  - platform: pca9685
    channel: 9
  - platform: pca9685
    channel: 10
  - platform: pca9685
    channel: 11
  - platform: pca9685
    channel: 12
  - platform: pca9685
    channel: 13
  - platform: pca9685
    channel: 14
  - platform: pca9685
    channel: 15
light:
  - platform: monochromatic
    output: PWM0
    output: PWM1
    output: PWM2
    output: PWM3
    output: PWM4
    output: PWM5
    output: PWM6
    output: PWM7
    output: PWM8
    output: PWM9
    output: PWM10
    output: PWM11
    output: PWM12
    output: PWM13
    output: PWM14
    output: PWM15
  - platform: rgbw
    red: PWM1
    green: PWM2
    blue: PWM3
    white: PWM4
    pin: 13
    inverted: false
    pin: 2
    inverted: false
RE: KC868-AP ESPHome demo config switch panel control LED for home assistant by ethernet - fra6767ita - 11-15-2023
Good morning,
I was wondering what type of button you use, I have your Kinkony buttons, and how to connect it to the kc868-Ap. Thanks
RE: KC868-AP ESPHome demo config switch panel control LED for home assistant by ethernet - admin - 11-15-2023
you can use any push button. just dry contact signal.
RE: KC868-AP ESPHome demo config switch panel control LED for home assistant by ethernet - fra6767ita - 11-16-2023
From the photo above there are two wires connected, from the button, to the kc868-Ap, one to gnd and one to dI-1, so only these two connected?
RE: KC868-AP ESPHome demo config switch panel control LED for home assistant by ethernet - admin - 11-16-2023
yes, you are right.
