V1.5 Schematic / PCB layout... - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A8 (https://www.kincony.com/forum/forumdisplay.php?fid=23) +--- Thread: V1.5 Schematic / PCB layout... (/showthread.php?tid=2905) |
V1.5 Schematic / PCB layout... - application_ninja - 05-12-2023 Is the schematic / PCB layout available for the latest -A8, rev 1.5? I'd like to add Power Over Ethenet to the product... RE: V1.5 Schematic / PCB layout... - admin - 05-12-2023 schematic PDF you can download from here: https://www.kincony.com/download/KC868-A8-PCBV1.4.pdf if you want to use POE, just add a POE adapter is ok. RE: V1.5 Schematic / PCB layout... - application_ninja - 05-12-2023 (05-12-2023, 12:26 AM)admin Wrote: schematic PDF you can download from here: https://www.kincony.com/download/KC868-A8-PCBV1.4.pdf So there are no changes from V1.4 to V1.5? I'd prefer to have POE built in, not an adapter, is there any PCB design files available? RE: V1.5 Schematic / PCB layout... - admin - 05-12-2023 So there are no changes from V1.4 to V1.5? no change. sorry, no PCB design files. in furture we will develop board with POE. RE: V1.5 Schematic / PCB layout... - application_ninja - 05-12-2023 (05-12-2023, 12:29 AM)admin Wrote: So there are no changes from V1.4 to V1.5? no change. That's a shame, I need a POE solution now, and an adapter won't work for my situation. RE: V1.5 Schematic / PCB layout... - admin - 05-12-2023 developing POE 16 channel relay board. whether suitable for you? RE: V1.5 Schematic / PCB layout... - application_ninja - 05-13-2023 (05-12-2023, 10:42 AM)admin Wrote: developing POE 16 channel relay board. whether suitable for you? I actually need a 6 port POE solution, that's why I wanted the schematics and PCB design, to modify the A8 for 6 port with POE. |
