KC868-A8 Voltage tolerance - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A8 (https://www.kincony.com/forum/forumdisplay.php?fid=23) +--- Thread: KC868-A8 Voltage tolerance (/showthread.php?tid=2909) |
KC868-A8 Voltage tolerance - andhol - 05-13-2023 Hi! I am planning to use a KC868-A8 in a vehicle, power by battery. What is the input voltage tolerance of the board? Could it handle like, 10-15 volts, or do I have to add a regulator to make sure it gets exactly 12V? /A A RE: KC868-A8 Voltage tolerance - admin - 05-14-2023 it use by DC12v, because the power is directly use by Relay's coin. if voltage is higher, it's not good for relay while work long time. |
