MQTT Example - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-M16 / M1 / MB / M30 (https://www.kincony.com/forum/forumdisplay.php?fid=50) +--- Thread: MQTT Example (/showthread.php?tid=2929) |
MQTT Example - MonsterJoe - 05-19-2023 // Example to read channel 1 and output to MQTT server // Patched together from the other examples // Install EmonLib and PubSubClient #include <ETH.h> #include <PubSubClient.h> #include "Arduino.h" #include "EmonLib.h" EnergyMonitor emon1; #define ETH_ADDR 0 #define ETH_POWER_PIN -1 #define ETH_MDC_PIN 23 #define ETH_MDIO_PIN 18 #define ETH_TYPE ETH_PHY_LAN8720 #define ETH_CLK_MODE ETH_CLOCK_GPIO17_OUT // WiFiUDP Udp; //Create UDP object unsigned int localUdpPort = 4196; //local port IPAddress local_ip(10, 0, 0, 143); IPAddress gateway(10, 0, 0, 1); IPAddress subnet(255, 255, 255, 0); IPAddress dns(10, 0, 0, 1); #define s0 32 #define s1 33 #define s2 13 #define s3 16 #define IN3 35 int toggleState_1 = 1; //Define integer to remember the toggle state for relay 1 int toggleState_2 = 1; //Define integer to remember the toggle state for relay 2 int toggleState_3 = 1; //Define integer to remember the toggle state for relay 3 int toggleState_4 = 1; //Define integer to remember the toggle state for relay 4 // Update these with values suitable for your network. const char* mqttServer = "10.0.0.16"; const char* mqttUserName = ""; // MQTT username const char* mqttPwd = ""; // MQTT password const char* clientID = "clientId"; // client id WiFiClient espClient; PubSubClient client(espClient); int value = 0; void setup_ethernet() { ETH.begin(ETH_ADDR, ETH_POWER_PIN, ETH_MDC_PIN, ETH_MDIO_PIN, ETH_TYPE, ETH_CLK_MODE); //start with ETH if (ETH.config(local_ip, gateway, subnet, dns, dns) == false) { Serial.println("LAN8720 Configuration failed."); }else{Serial.println("LAN8720 Configuration success.");} Serial.println("Connected"); Serial.print("IP Address:"); Serial.println(ETH.localIP()); } void reconnect() { while (!client.connected()) { if (client.connect(clientID, mqttUserName, mqttPwd)) { Serial.println("MQTT connected"); // ... and resubscribe } else { Serial.print("failed, rc="); Serial.print(client.state()); Serial.println(" try again in 5 seconds"); // Wait 5 seconds before retrying delay(5000); } } } void callback(char* topic, byte* payload, unsigned int length) { Serial.print("Message arrived ["); Serial.print(topic); Serial.print("] "); Serial.println(""); } String byteToHexString(uint8_t byte) { String hexStr = String(byte, HEX); if (hexStr.length() == 1) { hexStr = "0" + hexStr; } return hexStr; } void setup() { Serial.begin(115200); pinMode(s0,OUTPUT); pinMode(s1,OUTPUT); pinMode(s2,OUTPUT); pinMode(s3,OUTPUT); pinMode(IN3,INPUT); setup_ethernet(); client.setBufferSize(2048); client.setServer(mqttServer, 1883); client.setCallback(callback); emon1.current(IN3, 20); // ADC_PIN is the pin where SCT013 is connected, 20 amps } void loop() { if (!client.connected()) { reconnect(); } client.loop(); Serial.println("done loop"); // Set Low/High to flag for the input to read from: 0000 = chanel 1 to 1111 chanel 16 digitalWrite(s0,LOW); digitalWrite(s1,LOW); digitalWrite(s2,LOW); digitalWrite(s3,LOW); if(analogRead(IN3)!=0){ double Irms = emon1.calcIrms(1480); // Calculate Irms only, 1480 is num samples per second Irms = Irms * 110; // 110v Serial.printf("A3 on CH1=%d\n",Irms); String val = "val 1 " + String(Irms); client.publish("sensorData", val.c_str()); } delay(2000); } RE: MQTT Example - admin - 05-20-2023 thanks for share your code. |
