NTC 10k - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A8S (https://www.kincony.com/forum/forumdisplay.php?fid=24) +--- Thread: NTC 10k (/showthread.php?tid=2941) |
NTC 10k - GDN20 - 05-24-2023 how to connect an NTC 10K thermistor and get readings? RE: NTC 10k - admin - 05-25-2023 A8S can't directly connect with NTC 10K thermistor. suggest use a extender module for NTC. RE: NTC 10k - GDN20 - 06-03-2023 (05-25-2023, 12:35 AM)admin Wrote: A8S can't directly connect with NTC 10K thermistor. suggest use a extender module for NTC.Can be connected to +3v and A1. And a 10K resistor between GND and A1. You need to write the sketch correctly. RE: NTC 10k - admin - 06-03-2023 work well now? RE: NTC 10k - GDN20 - 06-03-2023 (06-03-2023, 03:56 PM)admin Wrote: work well now? with a correction factor from 5v to 3v accuracy +- 1° RE: NTC 10k - admin - 06-03-2023 ok |
