Are the Other GPIO available in any way on the board ? - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A2 (https://www.kincony.com/forum/forumdisplay.php?fid=43) +--- Thread: Are the Other GPIO available in any way on the board ? (/showthread.php?tid=2968) |
Are the Other GPIO available in any way on the board ? - primeroz - 06-07-2023 I would like to access the other GPIOs if possible. are other gpio available on the board or is i2c expander the only way ? thanks RE: Are the Other GPIO available in any way on the board ? - admin - 06-08-2023 what device you want to connected? such as temperature sensor? or .... ? RE: Are the Other GPIO available in any way on the board ? - primeroz - 06-08-2023 Mainly PIR motion sensors, but does it matter ? RE: Are the Other GPIO available in any way on the board ? - admin - 06-08-2023 There are 2 DI , you can use for your PIR sensor. RE: Are the Other GPIO available in any way on the board ? - primeroz - 06-08-2023 Thank you, yeah i am using those 2 already What i need to know is if any of the other GPIO that the esp32 chipset support is available so i can connect more than 2 PIR Sensors or if using `i2c` is my only option thanks |
