Digital inputs - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A6 (https://www.kincony.com/forum/forumdisplay.php?fid=22) +--- Thread: Digital inputs (/showthread.php?tid=2974) |
Digital inputs - bsarevalo - 06-12-2023 Hello everyone ! Is it possible to connect a 3.3V input to one of the connectors of the module? RE: Digital inputs - admin - 06-12-2023 you can try, maybe 3.3v will not trigger. RE: Digital inputs - bsarevalo - 06-12-2023 (06-12-2023, 09:59 PM)admin Wrote: you can try, maybe 3.3v will not trigger.Looking at the schematic from DI-1 to DI-6 they are activated with 0V since the common is +12V. But maybe you could help me if I use them in the analog inputs, I just want to know if I can make this connection, my reference voltage is 0 - 3.3 V it is the voltage of the KINCONY A6 board ... thanks in advance .. RE: Digital inputs - bsarevalo - 06-12-2023 (06-12-2023, 10:25 PM)bsarevalo Wrote:(06-12-2023, 09:59 PM)admin Wrote: you can try, maybe 3.3v will not trigger.Looking at the schematic from DI-1 to DI-6 they are activated with 0V since the common is +12V. But maybe you could help me if I use them in the analog inputs, I just want to know if I can make this connection, my reference voltage is 0 - 3.3 V it is the voltage of the KINCONY A6 board ... thanks in advance .. It's solved! I just wanted an advice or opinion from the manufacturer! I have connected the analog input A1, but I have configured it as a digital input in the program! it works perfectly ! thank you ! RE: Digital inputs - admin - 06-13-2023 ok, good. |
