Mqtt and switches - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-AM (https://www.kincony.com/forum/forumdisplay.php?fid=45) +--- Thread: Mqtt and switches (/showthread.php?tid=2981) |
Mqtt and switches - philippe - 06-15-2023 Hi , I d like my switches to not act on my relays. And instead, they should send MQTT messages stating "switch 1 action ON". I tried according to the tasmota pages https://tasmota.github.io/docs/Buttons-and-Switches/#ac-frequency-detection-switch to do it, setoption 114 ou 15, but I dont see any mqtt message when pressing a switch. Can you help? Thanks RE: Mqtt and switches - admin - 06-15-2023 SwitchMode1 1 SwitchTopic 0 Rule1 on Switch1#state=1 do publish stat/%topic%/PIR1 ON endon on Switch1#state=0 do Publish stat/%topic%/PIR1 OFF endon Rule1 1 i think you can do as this, such as the PIR sensor: https://tasmota.github.io/docs/PIR-Motion-Sensors/ RE: Mqtt and switches - philippe - 06-16-2023 The pb is that I have not yet learn the arduino stuff. Any possibility to update the bin file for me? Thanks RE: Mqtt and switches - admin - 06-16-2023 you are seeing tasmota solution. it's not use by arduino code. just set config as tasmota's guide. |
