K868-E16S use digital input and I2C in the same time - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-E16S/E16P (https://www.kincony.com/forum/forumdisplay.php?fid=26) +--- Thread: K868-E16S use digital input and I2C in the same time (/showthread.php?tid=3026) |
K868-E16S use digital input and I2C in the same time - Jtefan - 06-28-2023 I've defined the digital inputs and switches as in the example and also added a DS18B20 temp sensor to the I2C. But as soon as I add in yaml the Dallas configuration, the update_interval toggles the switches on and off at the interval set in the update_interval. I saw that the I2C port is the same as the Dallas sensor but I don't know how I can connect them in a different way. esphome: name: kincony-kc868-e16s friendly_name: Kincony KC868-E16S platform: ESP32 board: esp32dev logger: captive_portal: i2c: sda: 16 scl: 15 scan: true id: bus_a pcf8574: - id: 'pcf8574_hub_out_1' # for output channel 1-8 address: 0x21 - id: 'pcf8574_hub_out_2' # for output channel 9-16 address: 0x25 - id: 'pcf8574_hub_in_1' # for input channel 1-8 address: 0x22 - id: 'pcf8574_hub_in_2' # for input channel 9-16 address: 0x24 switch: - platform: gpio name: "e16s-output14" pin: pcf8574: pcf8574_hub_out_2 number: 5 mode: OUTPUT inverted: true id: output14 - platform: gpio name: "e16s-output15" pin: pcf8574: pcf8574_hub_out_2 number: 6 mode: OUTPUT inverted: true id: output15 - platform: gpio name: "e16s-output16" pin: pcf8574: pcf8574_hub_out_2 number: 7 mode: OUTPUT inverted: true id: output16 binary_sensor: - platform: gpio name: "DI1 - Entrance Left B1" pin: pcf8574: pcf8574_hub_in_2 number: 7 mode: INPUT inverted: true internal: true on_press: then: - switch.toggle: output14 dallas: - pin: 16 update_interval: 30s sensor: - platform: dallas address: 0x453c430457d4c928 name: "Livingroom Temperature" id: livingroom_temperature - platform: dallas address: 0x9d3c450457bfc728 name: "Bedroom Temperature" id: bedroom_temperature RE: K868-E16S use digital input and I2C in the same time - admin - 06-28-2023 DS18B20 can't use I2C bus pin. if you want to use DS18B20, try to use other free GPIO, such as there is a serial port extender on PCB (white 4pin socket). RE: K868-E16S use digital input and I2C in the same time - Jtefan - 06-29-2023 Thank you for the info, it was a confirmation of what I have to do. So, I've used RX from the extended serial pin GPIO14. Also I've added a 4.7K resistor between data and VCC+ (3.3V) of the temp sensor. It's not working without the resistor, that's why it wasn't working yesterday. dallas: - pin: 14 update_interval: 10s Thank you! RE: K868-E16S use digital input and I2C in the same time - admin - 06-29-2023 RXD:GPIO14 TXD:GPIO33 you can try to use by GPIO14 or GPIO33, if GPIO14 not work, you can try GPIO33. RE: K868-E16S use digital input and I2C in the same time - Jackson - 05-27-2024 Hi, I need some help with connecting DS18B20 sensor to E16S, can you make some tutorial or screenshots? The sensor have 3 wire, but serial on the PCB have 4! Help! Thx in advance, im begginer! RE: K868-E16S use digital input and I2C in the same time - admin - 05-27-2024 DS18B20 3 wire: 3.3v, gnd, data. connect these pins with board. RE: K868-E16S use digital input and I2C in the same time - Jackson - 05-28-2024 (05-27-2024, 11:44 PM)admin Wrote: DS18B20 3 wire: 3.3v, gnd, data. connect these pins with board. Where, how? Can you put here some screenshot? Thx in advance! RE: K868-E16S use digital input and I2C in the same time - admin - 05-28-2024 please search by google, how to use ds18b20 RE: K868-E16S use digital input and I2C in the same time - Jackson - 05-28-2024 (05-28-2024, 01:45 AM)admin Wrote: please search by google, how to use ds18b20 Are you kidding me? I know how to connect DS18B20 to ESP32, i have a working project on this, but i dont know how to connect DS18B20 tou your PCB(E16S)! NOW you understand? If you can put here some guide or screenshot, is OK, if not, Bye, bye! |
