DAC1/2 - Printable Version
+--- Thread: DAC1/2 (/showthread.php?tid=3035)
DAC1/2 - gilad - 07-05-2023
trying to use DAC1/2 by following simple code:
can't see any changes on output nor on esp32(25/26)
dac_output_enable(DAC_CHANNEL_1);
dac_output_enable(DAC_CHANNEL_2);
dac_output_voltage(DAC_CHANNEL_1,0);
dac_output_voltage(DAC_CHANNEL_2,0);
i see no changes no matter the values, how come ?
what is the meaning for Strapping is it needed any human interact to activate it?
RE: DAC1/2 - admin - 07-05-2023
this is arduino DAC demo source code for KC868-A6:
https://www.kincony.com/forum/showthread.php?tid=1861
RE: DAC1/2 - gilad - 07-06-2023
arduino code works for me but idf with c library isnt. nned to know the reason than as those are same in this level
sorry its look like hardware issue. with other A6 modules it works easy.
RE: DAC1/2 - admin - 07-06-2023
the board can't work by ESP-IDF, whether can work with our arduino demo source code?
