kc868-a6 use 2 sensor inputs for analog input - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A6 (https://www.kincony.com/forum/forumdisplay.php?fid=22) +--- Thread: kc868-a6 use 2 sensor inputs for analog input (/showthread.php?tid=3037) |
kc868-a6 use 2 sensor inputs for analog input - Siebje - 07-05-2023 Hi, Is there any way to use the two sensor inputs: I mean the two IO1 and IO2 pins. is there any way I can read/connect a 0-10 volt sensor to and read out the voltage/analogvalue? thanks for any help in advance! RE: kc868-a6 use 2 sensor inputs for analog input - admin - 07-05-2023 IO1 and IO2 use by digital signal, not for analog input, if you want to use analog input, please use A1,A2,A3,A4 ports. |
