MQTT SET syntax - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: "KCS" v2 firmware system (https://www.kincony.com/forum/forumdisplay.php?fid=40) +--- Thread: MQTT SET syntax (/showthread.php?tid=3038) |
MQTT SET syntax - philippe - 07-05-2023 Hello, What is the exact syntax to send Relay1 ON with MQTT. I am reading the document , I have my module sending State data, but cant find the right syntax to end orders. Thanks RE: MQTT SET syntax - admin - 07-05-2023 which board you are using? please upload some photo, how you write your mqtt command. RE: MQTT SET syntax - philippe - 07-07-2023 I Use the 4A. Finally I read again the litterature and find the right syntax. I was confused with using the parenthesis..Thank you RE: MQTT SET syntax - admin - 07-07-2023 ok |
