KCS Software and Arduino script - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: KCS Software and Arduino script (/showthread.php?tid=3070) |
KCS Software and Arduino script - alessiovietri - 07-11-2023 Hi everybody, We're trying to use an arduino script (with homespan, to connect the board to homekit) and the KCS software (to use the tuya connection), but if we install the arduino script, we lose the KCS software interface. We aim to: - use the arduino script to connect homekit (actually working) - connect tuya devices to the board Is is possible to achieve this? Thanks in advance RE: KCS Software and Arduino script - admin - 07-11-2023 the best way is chose KC868-H32B Pro relay controller. it can work with Homekit and tuya directly, without any code. KCS firmware and your own code can't run at the same time. RE: KCS Software and Arduino script - alessiovietri - 07-11-2023 (07-11-2023, 02:03 PM)admin Wrote: the best way is chose KC868-H32B Pro relay controller. it can work with Homekit and tuya directly, without any code. Ok, thank you for your answer. The relays mounted on the board KC868-H32B Pro are NO or NC? Could you also tell me the amperage of those relays? Thank you very much RE: KCS Software and Arduino script - admin - 07-11-2023 KC868-H32B Pro relay is COM and NO, without NC. relay current MAX : AC220V 7A, if use the load <5A is better. |
