Cant connect after FW update - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: Cant connect after FW update (/showthread.php?tid=3150) |
Cant connect after FW update - freedom1711 - 08-16-2023 Did FW update so I can connect loxone. IP address changed I still cant connect after reboot led lights were red and yellow normally they are red and blue. Please advise, since nobody is able to do live support after selling me the product. After power reboot Red, Blue & yellow light are on RE: Cant connect after FW update - admin - 08-16-2023 because new firmware support use multi protocol at the same time. so some LED will ON together. if you want to use Loxone, enable Loxone option in config webpage. fill your Loxone miniserver IP address and port. any quesitons post at here, support support by forum is better. we will feedback at here. |
