KC868-D16 inputs - Printable Version
+--- Forum: KC868-AP / ADR (https://www.kincony.com/forum/forumdisplay.php?fid=38)
+--- Thread: KC868-D16 inputs (/showthread.php?tid=3167)
KC868-D16 inputs - Valter - 08-20-2023
Good Morning,
Is it possible to have the inputs independent of the dimmers in MQTT ?
The ideia is to use these inputs in home assistant to actuate others elements in my house.
The ideia is to publish the state of these inputs.
Is this available in any firmware version for KC868-D16 ?
Thank you
Best regards
RE: KC868-D16 inputs - admin - 08-20-2023
sorry, D16's digital input use for dimmer internal. not send message by mqtt. if you want add INPUT for home assistant, suggest add another KC868-AI INPUT module.
RE: KC868-D16 inputs - Valter - 08-20-2023
(08-20-2023, 11:28 AM)admin Wrote: sorry, D16's digital input use for dimmer internal. not send message by mqtt. if you want add INPUT for home assistant, suggest add another KC868-AI INPUT module.
Ok. Thank you.
Or I can you a KC868-Axx (and use the outputs for other purpose)?
Thank you
yes, KC868-A series board have INPUT and OUTPUT, that can use for MQTT independently.
