DS18B20 with COLB - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: DS18B20 with COLB (/showthread.php?tid=318) |
DS18B20 with COLB - ahcdias - 06-29-2021 Is it possible to work with more than one DS18B20 in the same channel of the COL-B? I would like to monitor more than 5 temperature points... RE: DS18B20 with COLB - admin - 06-29-2021 now every DS18B20 temperature channel connect with 1 sensor. if you want to use more sensor, I think you can use analog input ports for more temperature senors, just chose 0-5v temperature sensor is ok. |
