12v irrigation solenoid getting really hot! - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A8S (https://www.kincony.com/forum/forumdisplay.php?fid=24) +--- Thread: 12v irrigation solenoid getting really hot! (/showthread.php?tid=3190) |
12v irrigation solenoid getting really hot! - Vendril - 08-23-2023 Hi, Using ESPHome and HomeAssistant. Have hooked up a 12v irrigation solenoid (normally closed) to relay 8 but it is getting really hot even when it is off. I have it wired and coded like this: 12v jumper cable (from the board power) to the (COM) on relay 8 GND jumper cable (from the board power) to the solenoid (NC) to the solenoid Code: - platform: gpioThanks, RE: 12v irrigation solenoid getting really hot! - admin - 08-23-2023 1. what hot? irrigation solenoid hot? or A8S board's relay hot? 2. what's your irrigation solenoid working current? RE: 12v irrigation solenoid getting really hot! - Vendril - 08-23-2023 Hi KinCony The valve is getting hot. It is this one - https://www.hillsirrigation.com.au/shop/irrigation/solenoid-valves/hr-valves/20mm-mv75-12vdc-micro-solenoid-valve/ has a stamp of 7W on the top of the valve. Have I wired it correctly? Thanks RE: 12v irrigation solenoid getting really hot! - admin - 08-23-2023 you can test it, connect your power supply to valve directly, without A8S board. if also hot, check with valve datasheet, is the temperature within the normal operating range. RE: 12v irrigation solenoid getting really hot! - Vendril - 08-24-2023 It is normally closed solenoid. should it get hot when relay is off? EDIT: Never mind. I had it wired wrong. Thanks RE: 12v irrigation solenoid getting really hot! - admin - 08-24-2023 ok. |
