DI Interrupts - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A6 (https://www.kincony.com/forum/forumdisplay.php?fid=22) +--- Thread: DI Interrupts (/showthread.php?tid=3227) |
DI Interrupts - Eric66 - 09-02-2023 Hi, Looking at the schematics I’m not 100% sure if the PCF8574 INT line is connected to the ESP32 or not. I would be very grateful if somebody could confirm if this is the case. I can see there’s a pull-up resistor, which I’m surprise because I though the PCF has an internal resistor anyway. If it is connected to the ESP32 I would greatly apreciate any information on this subject. Thanks in advance! Eric RE: DI Interrupts - admin - 09-03-2023 our ESP32 board, A6's PCF8574 not used "INT" pin with ESP32 chip. RE: DI Interrupts - Eric66 - 09-03-2023 Thank you for the clarification! Best regards: Eric |
