Create light switch in home assistant using MQTT - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: Create light switch in home assistant using MQTT (/showthread.php?tid=3298) |
Create light switch in home assistant using MQTT - truongdq54 - 09-20-2023 If I create a switch, it works ok, switch: - name: 'a16-kcs-output-1' unique_id: a16-kcs-output-1 state_topic: 'KC868_A16/B0B21CCF0978/STATE' command_topic: 'KC868_A16/B0B21CCF0978/SET' payload_on: '{"output1":{"value":true}}' payload_off: '{"output1":{"value":false}}' value_template: '{{ value_json.output1.value }}' state_on: true state_off: false But if I create a "light", light: - name: 'my_led' unique_id: a16-kcs-output-led-wc-1 state_topic: 'KC868_A16/B0B21CCF0978/STATE' command_topic: 'KC868_A16/B0B21CCF0978/SET' payload_on: '{"output1":{"value":true}}' payload_off: '{"output1":{"value":false}}' state_value_template: '{{ value_json.output1.value }}' the UI in home assistant showed "Unknown" status. Please help! RE: Create light switch in home assistant using MQTT - admin - 09-20-2023 i think you can use "switch", just change UI for "light" ico is better. RE: Create light switch in home assistant using MQTT - truongdq54 - 09-22-2023 Thank you, it works! |
