How to boot home assistant with sd card on cm4? - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-Server Raspberry Pi4 local server (https://www.kincony.com/forum/forumdisplay.php?fid=17) +--- Thread: How to boot home assistant with sd card on cm4? (/showthread.php?tid=3324) |
How to boot home assistant with sd card on cm4? - soethu - 09-25-2023 Hello, I'm new to Kincony. I installed home assistant on sd card and tried to boot on cm4 but it doesn't boot and showing as attached picture. RE: How to boot home assistant with sd card on cm4? - admin - 09-25-2023 do you use KC868-Server? if CM4 with KinCony's , it have eMMC. so can't use SD card. just install home assistant on eMMC. change jumper to "BOOT", then will use eMMC as as USB disk. we have video tour about it. |
