KC868-A32 wiring diagram - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A32/A32 Pro (https://www.kincony.com/forum/forumdisplay.php?fid=27) +--- Thread: KC868-A32 wiring diagram (/showthread.php?tid=3333) Pages:
1
2
KC868-A32 wiring diagram - KinCony Support - 09-27-2023 RE: KC868-A32 wiring diagram - shuhrat - 10-21-2023 Which pin to connect the ds18b20 temperature sensor to? RE: KC868-A32 wiring diagram - admin - 10-21-2023 if you want connect DS18B20, you can connect to extend serial port GPIO on the PCB. RE: KC868-A32 wiring diagram - johnsmith8439 - 11-03-2024 Good day, How do I output 12/24V for LED? Just replace light bulb in the diagram with 12/24V power supply and LED? RE: KC868-A32 wiring diagram - admin - 11-04-2024 yes, you are right. RE: KC868-A32 wiring diagram - johnsmith8439 - 11-04-2024 Thank you very much. RE: KC868-A32 wiring diagram - johnsmith8439 - 12-05-2024 Hello, How should I wire an AC-AC contactor? Do I need RC Snubber? I want to control a 20A water heater. Thank you every much. RE: KC868-A32 wiring diagram - admin - 12-05-2024 if you want to use AC-AC contactor, just let A32's relay output AC220V to contactor's coin. KC868-A32 designed PCB can work without RC snubber. RE: KC868-A32 wiring diagram - johnsmith8439 - 12-14-2024 Is the screws terminal for this board 3.81mm or 5.08mm? I mean something like this: https://www.aliexpress.com/item/1005007634896358.html In my project the wires have to come in from the side. I want to know if 3.81mm or 5.08mm will fit on A32. Thank you very much. RE: KC868-A32 wiring diagram - admin - 12-15-2024 if you are asking relay output green terminal, it's 5.00mm, NOT 5.08mm. |
