Water meter puls sensor on KC868-A16 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: Water meter puls sensor on KC868-A16 (/showthread.php?tid=3339) |
Water meter puls sensor on KC868-A16 - Jon - 09-27-2023 Hello, I have connected a inductive sensor (output 12v or 0v) to the digital input of the board in order to measure water usage in HA (Energy dashboard). In HA only a sensor can be selected and not a binary sensor which is the output of the config below. - platform: gpio id: water_pulse name: "water pulse" pin: pcf8574: pcf8574_hub_in_1 number: 7 mode: INPUT inverted: true How can I convert this binary sensor (id: water pulse) to a sensor that can be used in the Energy Dashboard of HA? There is a puls counter sensor function in ESPhome available but than I have to specify a pin number which is not directly selectable because of the I/O expander. Regards, Jon |
