Battery Backup - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: Battery Backup (/showthread.php?tid=3360) |
Battery Backup - MnM - 10-03-2023 Hi, Just got one of these units. It will be configured to work as an alarm system using various sensors around the house. I have a battery from the old alarm that this unit will replace - it there any way to connected it and use it? Will be a good option to be able to run on the battery if the power is cut. Thanks RE: Battery Backup - MnM - 10-08-2023 I have bought this device to give me battery back up. Hopefully it will work? https://vi.aliexpress.com/item/1005005170284381.html?spm=a2g0o.order_list.order_list_main.5.3c851802GhUFpy&gatewayAdapt=glo2vnm RE: Battery Backup - admin - 10-08-2023 this is a power supply automatic switch module, just wire as it's diagram, i think will be ok. |
