gas pressure sensor - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16S (https://www.kincony.com/forum/forumdisplay.php?fid=47) +--- Thread: gas pressure sensor (/showthread.php?tid=3365) |
gas pressure sensor - shuhrat - 10-06-2023 Hello how do I connect a gas pressure sensor https://sl.aliexpress.ru/p?key=62jhUXA RE: gas pressure sensor - admin - 10-07-2023 you can chose dc 0-5v output signal type of gas presure sensor. then connect to KinCony board's analog input port is ok. RE: gas pressure sensor - shuhrat - 10-07-2023 (10-07-2023, 12:15 AM)admin Wrote: you can chose dc 0-5v output signal type of gas presure sensor. then connect to KinCony board's analog input port is ok. What write to esphome I'm new to this RE: gas pressure sensor - admin - 10-07-2023 use ADC for ESPHome: https://esphome.io/components/sensor/adc.html RE: gas pressure sensor - shuhrat - 10-07-2023 (10-07-2023, 04:24 AM)admin Wrote: use ADC for ESPHome: https://esphome.io/components/sensor/adc.html can you help with the code |
