Help with pulse_counter config - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: Help with pulse_counter config (/showthread.php?tid=3373) |
Help with pulse_counter config - MnM - 10-09-2023 Hi, I would like some help to configure an input for count my water with pulse_counter I need to use a port that is connected directly to the ESP module. What PIN number should I define in my config: sensor: - platform: pulse_counter pin: number: XX?? mode: input: true pullup: true and which actual pin on the board that will be? (I suspect either GPIO 01, 02 or 03??) Thanks RE: Help with pulse_counter config - admin - 10-09-2023 yes, you can try, do you have test it? RE: Help with pulse_counter config - MnM - 10-09-2023 I have not test it because I don't know what try. What PIN number should I use in the above example assuming I will use GPIO01. Is that PIN 01? Is this the GPIO Pins? DS18B20/DHT11/DHT21/LED strip -1: 32 DS18B20/DHT11/DHT21/LED strip -2: 33 DS18B20/DHT11/DHT21/LED strip -2: 14 Is: GPIO01 = 32? GPIO02 = 33? GPIO03 = 14? RE: Help with pulse_counter config - admin - 10-10-2023 yes, all can use for digital input. RE: Help with pulse_counter config - MnM - 10-10-2023 (10-10-2023, 12:07 AM)admin Wrote: yes, all can use for digital input. Posting for information only so other users that want same kind of feature can use. OK I use used PIN 14 (GPIO3), VCC (12v) and ground: This is the relevant part of the ESPHome yaml: sensor: - platform: pulse_counter pin: number: 14 mode: input: true pullup: true It all works as it should. RE: Help with pulse_counter config - admin - 10-10-2023 thanks for your information. |
