Water Level Sensor Readings Not Changing with Water Level Variations - Printable Version
+--- Forum: "KCS" v2 firmware system (https://www.kincony.com/forum/forumdisplay.php?fid=40)
+--- Thread: Water Level Sensor Readings Not Changing with Water Level Variations (/showthread.php?tid=3438)
Pages: 1 2
Water Level Sensor Readings Not Changing with Water Level Variations - engmohades - 10-29-2023
Hello, I have a KC868-E16S board and installed the firmware KCS V2.1.9 on it. I connected a water level sensor that operates in the range of 0 to 5 volts and 0 to 0.7 meters.
I tested the sensor by placing it in a water tank with an actual height of 41 cm.
I noticed that the sensor reads up to 35 cm and the reading seems to remain constant even when the water level increases or decreases. For example, when I lowered the water level to 15 cm, the sensor did not register the change and the reading remained at 35 cm.
Similarly, when I increased the water level to 42 cm, the sensor reading did not change.
Can you help me solve this problem?
RE: Water Level Sensor Readings Not Changing with Water Level Variations - admin - 10-29-2023
what software you will use? for example : home asisstant? or you just want make a AUTOMATION to control relay?
RE: Water Level Sensor Readings Not Changing with Water Level Variations - engrezk - 10-29-2023
(10-29-2023, 08:05 AM)admin Wrote: what software you will use? for example : home asisstant? or you just want make a AUTOMATION to control relay?
First, I want to create an automation to control a relay without software , and then I will use Tuya software later
when have free time, we will test it then feedback to you.
RE: Water Level Sensor Readings Not Changing with Water Level Variations - engrezk - 10-31-2023
Hello, is there any update regarding the problem's solution?
RE: Water Level Sensor Readings Not Changing with Water Level Variations - admin - 10-31-2023
preparing one sensor with 70CM , then will begin test, when have news i will upload at here.
RE: Water Level Sensor Readings Not Changing with Water Level Variations - admin - 11-02-2023
i use KC868-E16T for testing, but KC868-E16S is same. connect water level sensor with analog input1.
because the water level sensor output signal is dc 0-5v. level range is 0--70cm
CHA1 and CHA2 use for 0-5v. CHA3 and CHA4 use for 4-20mA
i use pump later water full of bottle.
the big bottle concave about 2-3 cm.
when the water level is 46cm. i test with software and multi meter as follows:
when i change water level from 0-46cm, webpage will auto update the value. i think you need to confirm whether you have use analog 0-5v port?
later i will take a video tour about water level testing.
RE: Water Level Sensor Readings Not Changing with Water Level Variations - admin - 11-03-2023
video tour at here:
RE: Water Level Sensor Readings Not Changing with Water Level Variations - engmohades - 11-03-2023
Thank you for your effort. I have identified the mistake, which is connecting the water level sensor to point A4. I have connected it to point A1 instead, and the readings change as the level changes. Thank you.
Thank you very much. Now everything is working fine.
RE: Water Level Sensor Readings Not Changing with Water Level Variations - bansai - 02-26-2026
Hello
I've a KC868-A8Sv2 using 24V and I want to use with a water level sensor. Could it work with this https://es.aliexpress.com/item/1005007792967053.html ?
They have different voltaje Outputs: 4-20mA / 0-5V / 0-10V
How many sensors can I use with this board?
Thanks
4-20mA Output
0-5V Output
0-10V Output
