Future M16 ideas - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-M16 / M1 / MB / M30 (https://www.kincony.com/forum/forumdisplay.php?fid=50) +--- Thread: Future M16 ideas (/showthread.php?tid=3468) |
Future M16 ideas - Schmick - 11-04-2023 Great work on the M16v2! ![]() Some thoughts for a future version. Please don't take as criticism! Could the device be split in two for installation in a surface mount distribution board? I'm thinking that the clamp inputs and voltage inputs could maybe be connected to a DIN module with same dimensions as standard 3 or 4 pole breaker, then using an interface cable, connect that to another smaller low voltage module housing the ESP32, networking and other components. If the barrel jacks are removed from the clamps, could probably shrink the connections to 2x 16x2.54mm terminal blocks. By splitting the device in two, all the higher voltage wiring and clamp cables could then be neatly concealed and protected against accidental contact. Going even further, if the ADC was able to be done within that module, could maybe even just have the module expose an I2C interface on the front face allowing for lots of flexibility on the low voltage side in terms of how the data is exported. RE: Future M16 ideas - admin - 11-05-2023 thank you very much for suggestion, we will save your idea, maybe use for new model in furture. |
