publish sensor initial state at boot on home assistant after power failure - Printable Version
+--- Forum: Getting Started with ESPHome and Home Assistant (https://www.kincony.com/forum/forumdisplay.php?fid=54)
+--- Thread: publish sensor initial state at boot on home assistant after power failure (/showthread.php?tid=3498)
publish sensor initial state at boot on home assistant after power failure - admin - 11-10-2023
RE: publish sensor initial state at boot on home assistant after power failure - reza - 11-17-2023
what if we use a momentary switch, how to publish sensor initial state in boot after power fail or reboot on home assistant?
RE: publish sensor initial state at boot on home assistant after power failure - admin - 11-17-2023
not only use LATCH switch or MOMENTARY switch, the solution in video both suitable for using.
