KC868-ap - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-AP / ADR (https://www.kincony.com/forum/forumdisplay.php?fid=38) +--- Thread: KC868-ap (/showthread.php?tid=3508) |
KC868-ap - Gerrit - 11-12-2023 Hello, I received the board recently and was able to get it working with esphome. I am using this board to connect ledstrips with a voltage of 24v. Ik have also some downlights at 12v that I would like control with the board. I see that the powerrail is divided in 3 sections but connected to eachother. Would it be possible to separate one part and connect the 12v downlights with a 12v powersupply? If not what could be another solution. RE: KC868-ap - admin - 11-13-2023 sure, KC868-AP support DC12-24v. if you want to use DC12v led strip, just power supply use by DC12v is ok. RE: KC868-ap - Gerrit - 11-16-2023 (11-13-2023, 12:13 AM)admin Wrote: sure, KC868-AP support DC12-24v. if you want to use DC12v led strip, just power supply use by DC12v is ok. thanks for the answer. But perhaps, I did not explain my question well. What I would like to achive is to use 24v ledstrips and 12v downlights on the same kc868-ap board. I see that all the supplies are tight together on the circuit board. RE: KC868-ap - admin - 11-16-2023 no, can't use 24v and 12v different type of LED strip with one AP board at the same time. only chose one of voltage to use. |
