KC868-A6 Tasmota HA - Printable Version
+--- Thread: KC868-A6 Tasmota HA (/showthread.php?tid=3518)
KC868-A6 Tasmota HA - duekay@gmail.com - 11-13-2023
Hi,
I have managed to get Tasmota running nicely on the A6, the only issue I have is the integration of the PCF8574 inputs mapped into home assistant.
For some reason, they only show up as sensors. is there a way to map it through?
Thanks
RE: KC868-A6 Tasmota HA - admin - 11-13-2023
if you want use A6 for home assistant, suggest integrate A6 to home assistant by ESPHome directly, that will run nicely.
RE: KC868-A6 Tasmota HA - duekay@gmail.com - 11-25-2023
Figured it out,
For those that run into the same issue, make sure you don't modify your MQTT Full topic, keep it the  %topic%/%prefix% and it loads fine.
Think this is just a Tasmota / HA integration requirement with the auto-discovery. I had a similar issue with some Sonoff devices but I fixed it unintentionally lol
RE: KC868-A6 Tasmota HA - admin - 11-25-2023
ok, great.
