kc868-ak and button switch - Printable Version
+--- Thread: kc868-ak and button switch (/showthread.php?tid=3555)
kc868-ak and button switch - skench - 11-22-2023
Good afternoon.
Please tell me if I can connect a stupid button switch to the kc868-ak? For example https://ae04.alicdn.comhttps://ae04.alicdn.com/kf/Sb26afe9d58fd49eaad6fdbc03e88c884n.jpg ?
In the diagram we see "Lb1" and "Lb". On the kc868-ak board there are 36 numbered and 4 kcom. Please tell me how to connect correctly?
RE: kc868-ak and button switch - admin - 11-22-2023
it can use. just connect with digital input port and COM, 4 KCOM actually is same, on PCB all are together.
RE: kc868-ak and button switch - skench - 11-22-2023
Should I connect to the digital port Lb1 or Lb?
Which one of the four kcoms should I connect to?
(11-22-2023, 10:06 AM)admin Wrote: it can use. just connect with digital input port and COM, 4 KCOM actually is same, on PCB all are together.
RE: kc868-ak and button switch - admin - 11-23-2023
any port can be connected, but use by smart system, suggest you chose "momentary" switch panel, just a push-button type is better.
