ESPHOME, KC868-A4S, sim 800l - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A4S (https://www.kincony.com/forum/forumdisplay.php?fid=41) +--- Thread: ESPHOME, KC868-A4S, sim 800l (/showthread.php?tid=3567) |
ESPHOME, KC868-A4S, sim 800l - SERJ_lebedev - 11-28-2023 Hi, Can you advise me how to configure sim800l for use with esphome firmware? Currently yaml is like this: Code: uart: I have a TTGO T-Call V1.4 board with the same sim 800l module. everything works fine The only thing is that there are additional module settings in yaml: Code: switch: thanks! RE: ESPHOME, KC868-A4S, sim 800l - admin - 11-28-2023 # Example configuration entry uart: baud_rate: 9600 tx_pin: TX rx_pin: RX sim800l: on_sms_received: - logger.log: format: "Received '%s' from %s" args: [ 'message.c_str()', 'sender.c_str()' ] logger: baud_rate: 0 # disable uart logger on esp 8266 here is details by epshome: https://esphome.io/components/sim800l.html if can't work, you can exchange RXD, TXD pin define for a test. RE: ESPHOME, KC868-A4S, sim 800l - SERJ_lebedev - 11-28-2023 (11-28-2023, 12:17 PM)admin Wrote: if can't work, you can exchange RXD, TXD pin define for a test. Thank you so much! you are the best! swapped pins in yaml and everything works) RE: ESPHOME, KC868-A4S, sim 800l - admin - 11-28-2023 ok, good. |
