A24 arduino demo source code-06- Ethernet LAN8720 by UDP - Printable Version
+--- Forum: KinCony A24 (https://www.kincony.com/forum/forumdisplay.php?fid=56)
+--- Thread: A24 arduino demo source code-06- Ethernet LAN8720 by UDP (/showthread.php?tid=3797)
A24 arduino demo source code-06- Ethernet LAN8720 by UDP - KinCony Support - 12-07-2023
#include <ETH.h>
#include <WiFiUdp.h>
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN   18
#define ETH_TYPE       ETH_PHY_LAN8720
#define ETH_CLK_MODE   ETH_CLOCK_GPIO17_OUT
void setup()
  Serial.println();
  Serial.println("Connected");
  Serial.print("IP Address:");
void loop()
  if (packetSize)                     //if have received data
    char buf[packetSize];
    Serial.println();
    Serial.print("Received: ");
    Serial.println(buf);
    Serial.print("From IP: ");
    Serial.print("From Port: ");
    Udp.print("Received: ");
