KC868-H32BS roller blinds control - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: KC868-H32BS roller blinds control (/showthread.php?tid=3828) |
KC868-H32BS roller blinds control - Tase - 12-12-2023 Hi. Need an advice on wiring and programming 2 roller blinds. Normally, these should have been operated by 3 wires each, just that i have only 5 in total. My question if it would work to use L as com for all 4 output relays, as follows L -COM N1- UP N2-DOWN N3-UP N4-DOWN By setting interlock function in HA between the first and second relay and then for 3&4, i believe i have to change the script also. Is it enough to have them interlocked, or a change in yaml configuration would be the solution. Example: relay 1 ON relay 2 OFF relay3 OFF relay 4 OFF relay 1 OFF relay 2 ON relay 3 OFF relay 4 OFF relay 1 OFF relay 2 OFF relay 3 ON relay 4 OFF relay 1 OFF relay 2 OFF relay 3 OFF relay 4 ON .hanks for support RE: KC868-H32BS roller blinds control - admin - 12-12-2023 take a photo of your motor, need to understand your moter wire define firstly. |
